23-11-2017, 09:23 PM
If you choose to remove the triangular cover be very careful because it is hardened. If you remove the three screws and try to drift it there is a very good chance of breaking off one of the ears on the flange.
The only safe way to do this is to heat the gearbox casing up with a hot air gun until it is quite hot.
