Antifreeze
(28-10-2019, 09:20 AM)Atlantis Wrote: Is it worth putting Kseal in or is it not recommended??
As an MGF owner, I put Kseal in the bin!
If you have a leak, the leak needs fixing, Kseal is merely a bodge and causes it's own problems. Not so much of a issue in simple Austin Seven cooling systems, apart from completely blocking an already furred up radiator, but can be disastrous in complex modern systems, full of "jiggle valves", narrow passages and so on.
Antifreeze - by Atlantis - 27-10-2019, 11:17 PM
RE: Antifreeze - by Chris KC - 28-10-2019, 05:06 AM
RE: Antifreeze - by David Stepney - 28-10-2019, 08:40 AM
RE: Antifreeze - by Parazine - 28-10-2019, 09:04 AM
RE: Antifreeze - by Atlantis - 28-10-2019, 09:20 AM
RE: Antifreeze - by Chris KC - 28-10-2019, 09:51 AM
RE: Antifreeze - by Parazine - 28-10-2019, 10:18 AM
RE: Antifreeze - by Atlantis - 28-10-2019, 10:52 AM
RE: Antifreeze - by AustinWood - 28-10-2019, 11:04 AM
RE: Antifreeze - by Reckless Rat - 28-10-2019, 11:04 AM
RE: Antifreeze - by Chris KC - 28-10-2019, 11:59 AM
