25-09-2019, 11:27 AM
Matt photo of dropped axle (done by Ian Dunford at the time) and home made drop plates it also has a brake tie rod as hydraulic brake are fitted, there is a wedge on top the spring as the chassis had very little castor built in. The radius arm ball joint is dropped to match the 6 degrees of castor. Terry.
