  • 2 Vote(s) - 1.5 Average
1934 Austin 7 Box engine removal
Have you got a low chassis crankcase in the car? There is much less room due the engine mounts being lower on the crankcase than a high chassis crankcase.
If the rear catches the bulkhead, take the flywheel cover off. As Rick has noted undoing the throttle shaft can give you a bit more room.
With the gearbox disconnected you just have to tilt the engine to get the sump out if the V. And drag it forward over the nosepiece
1934 Austin 7 Box engine removal - by PeterW - 12-09-2019, 10:00 PM
RE: 1934 Austin 7 Box engine removal - by PeterW - 12-09-2019, 10:59 PM
RE: 1934 Austin 7 Box engine removal - by Rick F - 13-09-2019, 12:22 AM
RE: 1934 Austin 7 Box engine removal - by Hedd_Jones - 13-09-2019, 07:59 AM
RE: 1934 Austin 7 Box engine removal - by PeterW - 14-09-2019, 07:47 PM
