OK, I give up !!!!!!!
Sounds like the spark is in the wrong place.
I usually feel slightly superior to those who cannot get the ignition timing sorted.
Top of compression stroke - points just opening - where the rotor arm is becomes No. 1 - and off you go.
Applied this once to a '24 AC which the owner had given up on, and within a couple of minutes we were going for a drive.
Smug, or what?!
So - iI thoughtI would swap distributors to test the spare.   How easy is that?
Took me three goes and the plug leads are now not where they were.
At least one attempt was 180 degrees out.
Dunno why- but it isn't always easy, after all.
OK, I give up !!!!!!! - by flywheel1935 - 11-09-2019, 07:19 PM
RE: OK, I give up !!!!!!! - by Hugh Barnes - 11-09-2019, 08:53 PM
RE: OK, I give up !!!!!!! - by flywheel1935 - 11-09-2019, 09:07 PM
RE: OK, I give up !!!!!!! - by flywheel1935 - 11-09-2019, 09:45 PM
RE: OK, I give up !!!!!!! - by Colin Reed - 11-09-2019, 10:31 PM
RE: OK, I give up !!!!!!! - by Ray White - 12-09-2019, 12:53 AM
RE: OK, I give up !!!!!!! - by "Slack Alice" Simon - 12-09-2019, 07:05 AM
RE: OK, I give up !!!!!!! - by Mike Costigan - 12-09-2019, 08:20 AM
RE: OK, I give up !!!!!!! - by Roy Player - 12-09-2019, 08:42 AM
RE: OK, I give up !!!!!!! - by Colin Wilks - 12-09-2019, 09:01 AM
RE: OK, I give up !!!!!!! - by John Mason - 12-09-2019, 09:18 AM
RE: OK, I give up !!!!!!! - by Rick F - 12-09-2019, 09:41 AM
RE: OK, I give up !!!!!!! - by JohnD - 12-09-2019, 09:41 AM
RE: OK, I give up !!!!!!! - by Robert Leigh - 12-09-2019, 11:03 AM
RE: OK, I give up !!!!!!! - by Rick F - 12-09-2019, 11:50 AM
RE: OK, I give up !!!!!!! - by flywheel1935 - 12-09-2019, 04:32 PM
RE: OK, I give up !!!!!!! - by Rick F - 12-09-2019, 04:44 PM
RE: OK, I give up !!!!!!! - by John Mason - 12-09-2019, 05:21 PM
RE: OK, I give up !!!!!!! - by flywheel1935 - 12-09-2019, 07:07 PM
RE: OK, I give up !!!!!!! - by Leon s - 12-09-2019, 07:18 PM
RE: OK, I give up !!!!!!! - by Ruairidh Dunford - 12-09-2019, 07:19 PM
RE: OK, I give up !!!!!!! - by Alan - 12-09-2019, 07:48 PM
RE: OK, I give up !!!!!!! - by flywheel1935 - 12-09-2019, 09:12 PM
RE: OK, I give up !!!!!!! - by Alan - 12-09-2019, 10:02 PM
RE: OK, I give up !!!!!!! - by Rick F - 13-09-2019, 12:12 AM
RE: OK, I give up !!!!!!! - by Chris KC - 13-09-2019, 10:59 AM
RE: OK, I give up !!!!!!! - by flywheel1935 - 13-09-2019, 01:11 PM
RE: OK, I give up !!!!!!! - by Paul N-M - 14-09-2019, 01:04 PM
RE: OK, I give up !!!!!!! - by Zetomagneto - 14-09-2019, 10:23 PM
RE: OK, I give up !!!!!!! - by flywheel1935 - 15-09-2019, 01:51 PM
RE: OK, I give up !!!!!!! - by Roger - 30-04-2020, 11:05 PM
RE: OK, I give up !!!!!!! - by bob46320 - 01-05-2020, 07:04 AM
RE: OK, I give up !!!!!!! - by John Mason - 01-05-2020, 09:54 AM
RE: OK, I give up !!!!!!! - by Austin in the Shed - 01-05-2020, 10:18 AM
RE: OK, I give up !!!!!!! - by John Mason - 01-05-2020, 12:59 PM
RE: OK, I give up !!!!!!! - by flywheel1935 - 01-05-2020, 01:42 PM
RE: OK, I give up !!!!!!! - by Tony Press - 01-05-2020, 11:09 PM
RE: OK, I give up !!!!!!! - by Russlin - 03-05-2020, 12:13 PM
RE: OK, I give up !!!!!!! - by Tony Press - 03-05-2020, 11:15 PM
