  • 1 Vote(s) - 3 Average
track rod tie rod steering ends
Hi Ian
To labour all this yet further...
I was not absolutely sure which of the following you meant
1) the radius rods fine thread directly into the T bracket instead of the complex fittings ex track rod ends
2) The T piece fine threads into the axle (so no external nut required)
3) the rotating action for the axle tube ends is derived through one end being fine threaded over the main tube rather than the trapped flange arrangement of the original.
It is faintly possible others may also be curious!
track rod tie rod steering ends - by a7grenade - 05-06-2019, 09:01 PM
RE: track rod tie rod steering ends - by JonE - 05-06-2019, 10:54 PM
RE: track rod tie rod steering ends - by Bob Culver - 14-06-2019, 10:34 AM
