Crank case to block studs
Obviously past history of the case studs could be a factor, however it is my belief the the quality of SOME replacement studs is not good enough. In the past when being lazy I have used off the shelf studs and on occasion experienced rapid failure, I now never use studs where I am not 100% sure of the grade of the steel I have made them from and have not experienced further problems. I have also used a number of silicon gaskets and suffered no problems as a result, even with reasonably high CR and high lift cams. I assume you checked the top of the case was flat, they are often not, and you rectified as required, I also assume the case was not unduly loaded by the chassis?
RE: Crank case to block studs - by Chris KC - 18-04-2019, 07:51 AM
RE: Crank case to block studs - by Ian Williams - 18-04-2019, 08:21 AM
RE: Crank case to block studs - by Alan - 18-04-2019, 08:53 AM
RE: Crank case to block studs - by Speedex750 - 18-04-2019, 09:01 AM
RE: Crank case to block studs - by Ian Williams - 18-04-2019, 08:23 PM
RE: Crank case to block studs - by Alan - 18-04-2019, 10:03 PM
RE: Crank case to block studs - by Ian Williams - 19-04-2019, 06:07 AM
RE: Crank case to block studs - by AustinWood - 19-04-2019, 10:35 AM
RE: Crank case to block studs - by Greig Smith - 20-04-2019, 09:59 AM
RE: Crank case to block studs - by AustinWood - 20-04-2019, 10:06 AM
RE: Crank case to block studs - by Chris KC - 20-04-2019, 11:46 AM
RE: Crank case to block studs - by AustinWood - 20-04-2019, 12:19 PM
RE: Crank case to block studs - by Dave Wortley - 20-04-2019, 04:35 PM
