04-04-2019, 09:21 AM
Dennis, I agree with Colin that anti vibration mounts have merit but I would point out that, in my experience, they are good in compression, passable in shear for an exhaust mount but don't last too long in tension. If I were going down the rubber bobbin route, I might extend the 3mm steel brackets to sit under the original mountings on the tank like a hook with the anti vibration mounts sandwiched between the bracket and the mount on the tank. Just a suggestion.
Regards, Stuart
Regards, Stuart
