03-04-2019, 08:48 PM
HI All,
Before ordering a SPEEDI-SLEEVE the Dia of the shaft needs to be measured accurately because the min & max is only .006 th regardless of sleeve Dia.
Also the 99187 that Steve Jones uses is 5/16 narrower than the 99186 this allows the sleeve to Fit better on the shaft they should not be level with the end of the shaft but further on leaving a gap between end of shaft and sleeve and Definitely not Peened over
Colin
NZ
Colin
NZ
