29-01-2019, 08:27 PM
(This post was last modified: 29-01-2019, 09:18 PM by Colin Wilks.
Edit Reason: Terminology
Resurrecting this thread to ask if people can identify the linings I have here. Car is a '34 Type 65 with 4 speed syncro box. Clutch linings are riveted to flywheel and pressure plate. There's less than 1 mm above the rivets so I intend renewing them whilst I've got everything apart. Are these Borg & Beck or Newton Bennett?
Second question: The plate has rotated axially against it's central boss, which I assume means that it'll be the rivets that have worn as I think they're softer than the plate. "Clutch Boss Rivets" are available from our cherished suppliers at minimal cost, but how do you go about fitting them?
