04-10-2017, 08:06 AM
I have had the regrettable experience of being suckered through eBay I wish to warn other would be buyers.
The following link is to the seller;
[/url][url=http://www.ebay.com.au/itm/BRAND-NEW-36-SPOKES-CLASSIC-CAR-WHEEL-RIM-AUSTIN-A7-10-12-16-20-AUD-/282628032563?hash=item41cdf18833]http://www.ebay.com.au/itm/BRAND-NEW-36-SPOKES-CLASSIC-CAR-WHEEL-RIM-AUSTIN-A7-10-12-16-20-AUD-/282628032563?hash=item41cdf18833
Having bought the advertised A7 wheel for $290 Aust as per the attached link upon receipt it looked the business, I thought I was on a winner.
I had the wheel powder coated black and then a new tyre fitted. It was at this point when it was attempted to fit the wheel to the car I discovered the pitfalls of the purchase simply I had bought a lemon. The old expression of if it is too good to be true then it most likely is, come flooding in with vengeance.
The first fault is the hub center is 31tho to small in diameter and will not fit the diameter of the mounting hub being 3diameter.
The laced indexing of the spokes was incorrect with the spokes crossing over in front of the mounting stud. This fault will not allow a socket to be used to tighten the nuts.
While an easy fix the hole for the valve spigot is too small.
The last being there is six hole witness centers drilled that must have been wrong and these were disguised with a filler.
I have included photos in a hope these may make the preceding clearer, The telescopic gauge was set from an original wheel hub
Regards,
Doug Baker
Regards,
Doug Baker
