Shock absorber spring washers and lock nuts
(07-01-2019, 09:33 PM)Chris KC Wrote: Spring washers are at best barely effective as a locking device.
All the original 'flat' spring washers I have are springless and the later square section with the sharp ends are usually too brutal for an old Austin 7.
I don't use a spring washer with locknuts at all (put the full nut on first and lock with the half nut).
The tanged washer is necessary against the fibre washer on the dampers.
Cheers, Tony P.
RE: Shock absorber spring washers and lock nuts - by Tony Press - 08-01-2019, 12:15 AM
