20-08-2018, 04:26 PM
I have stayed with 6 volts and do not have led lighting. What I do have is a small box of tricks the size of a couple of machboxes which fits under the dashboard and it has some electric wizardry together with slight wiring changes to both the Dynamo and cut out so that I now have a two brush Dynamo that charges at a higher rate without damaging the battery because it workers similar that the new all singing all dancing battery chargers that switch charging on and off when required and will only allow a charging rate the battery is happy to except.
John Mason
John Mason
