10-08-2018, 09:50 AM
Buy some expensive gadget to lift heads/engines, the wallet has just locked up solid. Just find a dead 14 or 18mm plug and remove the ceramic centre, I crunch the ceramic in a vice covered in an old cloth to avoid splinters. Knock out any remains so the plug is now hollow and push a coach bolt or similar through the threaded end of the plug, bend the top into a hook or T, job jobbed. The plug end being free to rotate is so useful too when extracting and fitting engines.. Plug hole 3 with gearbox, 2 just engine.
Peter.
Peter.
