RP Rear brake cables
#26
When viewed as in your last photo; if the pendant section of your front lever was given a slight twist so that the ball presents at 90 degrees to the cable (when steering straight ahead) ,you'd eliminate the necking and save yourself a lot of filing. That said removing the 'step' next to the ball has fatigue merit.
This also will bring the endcap a tad further away from the backing plate and the levers are of course left and right handed.
I have seen many so modified and they can't have been from panic stops so is this recommended practice?
Others have mentioned the importance of eliminating lost motion from the lever onward, so that the pendant portion can be closer to vertical at rest and then 90 degrees to the cable at full braking.  cheers  Russell
RP Rear brake cables - by Roger - 27-06-2018, 03:52 PM
RE: RP Rear brake cables - by Chris KC - 27-06-2018, 04:05 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 04:42 PM
RE: RP Rear brake cables - by Chris KC - 27-06-2018, 04:48 PM
RE: RP Rear brake cables - by Robert Leigh - 28-06-2018, 10:54 AM
RE: RP Rear brake cables - by dickie65 - 27-06-2018, 05:55 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 09:29 PM
RE: RP Rear brake cables - by Hentzant - 27-06-2018, 06:29 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 09:17 PM
RE: RP Rear brake cables - by Ian Williams - 27-06-2018, 09:26 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 11:12 PM
RE: RP Rear brake cables - by Tony Press - 28-06-2018, 03:36 AM
RE: RP Rear brake cables - by Roger - 28-06-2018, 11:33 AM
RE: RP Rear brake cables - by AustinWood - 27-06-2018, 11:44 PM
RE: RP Rear brake cables - by Ian Williams - 28-06-2018, 09:19 PM
RE: RP Rear brake cables - by Roger - 01-07-2018, 06:52 PM
RE: RP Rear brake cables - by Ian Williams - 01-07-2018, 09:04 PM
RE: RP Rear brake cables - by Roger - 01-07-2018, 10:02 PM
RE: RP Rear brake cables - by Ian Williams - 01-07-2018, 11:53 PM
RE: RP Rear brake cables - by Ruairidh Dunford - 02-07-2018, 07:05 AM
RE: RP Rear brake cables - by Roger - 02-07-2018, 02:00 PM
RE: RP Rear brake cables - by Tony Press - 02-07-2018, 11:21 PM
RE: RP Rear brake cables - by Roger - 02-07-2018, 11:37 PM
RE: RP Rear brake cables - by Tony Press - 02-07-2018, 11:56 PM
RE: RP Rear brake cables - by Roger - 03-07-2018, 07:21 PM
RE: RP Rear brake cables - by squeak - 04-07-2018, 01:11 AM
RE: RP Rear brake cables - by AustinWood - 04-07-2018, 06:17 AM
RE: RP Rear brake cables - by Roger - 04-07-2018, 09:48 AM
RE: RP Rear brake cables - by squeak - 04-07-2018, 12:48 PM
RE: RP Rear brake cables - by Tony Press - 05-07-2018, 12:15 AM
RE: RP Rear brake cables - by Roger - 04-07-2018, 01:07 PM
RE: RP Rear brake cables - by Ruairidh Dunford - 05-07-2018, 07:16 AM
RE: RP Rear brake cables - by dickie65 - 06-07-2018, 09:07 PM
RE: RP Rear brake cables - by squeak - 07-07-2018, 01:19 AM
RE: RP Rear brake cables - by Bob Culver - 07-07-2018, 04:44 AM
RE: RP Rear brake cables - by Tony Press - 07-07-2018, 06:04 AM
RE: RP Rear brake cables - by Roger - 07-07-2018, 09:09 AM
RE: RP Rear brake cables - by Roger - 07-07-2018, 10:34 PM
