RP Rear brake cables
A photo of your front set up will help us understand the issue, again the ball should face the backplate, this places it directly under the King Pin so that it remains in the same place as you turn the steering, facing away from the backplate it will describe an arc.
RP Rear brake cables - by Roger - 27-06-2018, 03:52 PM
RE: RP Rear brake cables - by Chris KC - 27-06-2018, 04:05 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 04:42 PM
RE: RP Rear brake cables - by Chris KC - 27-06-2018, 04:48 PM
RE: RP Rear brake cables - by Robert Leigh - 28-06-2018, 10:54 AM
RE: RP Rear brake cables - by dickie65 - 27-06-2018, 05:55 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 09:29 PM
RE: RP Rear brake cables - by Hentzant - 27-06-2018, 06:29 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 09:17 PM
RE: RP Rear brake cables - by Ian Williams - 27-06-2018, 09:26 PM
RE: RP Rear brake cables - by Roger - 27-06-2018, 11:12 PM
RE: RP Rear brake cables - by Tony Press - 28-06-2018, 03:36 AM
RE: RP Rear brake cables - by Roger - 28-06-2018, 11:33 AM
RE: RP Rear brake cables - by AustinWood - 27-06-2018, 11:44 PM
RE: RP Rear brake cables - by Ian Williams - 28-06-2018, 09:19 PM
RE: RP Rear brake cables - by Roger - 01-07-2018, 06:52 PM
RE: RP Rear brake cables - by Ian Williams - 01-07-2018, 09:04 PM
RE: RP Rear brake cables - by Roger - 01-07-2018, 10:02 PM
RE: RP Rear brake cables - by Ian Williams - 01-07-2018, 11:53 PM
RE: RP Rear brake cables - by Ruairidh Dunford - 02-07-2018, 07:05 AM
RE: RP Rear brake cables - by Roger - 02-07-2018, 02:00 PM
RE: RP Rear brake cables - by Tony Press - 02-07-2018, 11:21 PM
RE: RP Rear brake cables - by Roger - 02-07-2018, 11:37 PM
RE: RP Rear brake cables - by Tony Press - 02-07-2018, 11:56 PM
RE: RP Rear brake cables - by Roger - 03-07-2018, 07:21 PM
RE: RP Rear brake cables - by squeak - 04-07-2018, 01:11 AM
RE: RP Rear brake cables - by AustinWood - 04-07-2018, 06:17 AM
RE: RP Rear brake cables - by Roger - 04-07-2018, 09:48 AM
RE: RP Rear brake cables - by squeak - 04-07-2018, 12:48 PM
RE: RP Rear brake cables - by Tony Press - 05-07-2018, 12:15 AM
RE: RP Rear brake cables - by Roger - 04-07-2018, 01:07 PM
RE: RP Rear brake cables - by Ruairidh Dunford - 05-07-2018, 07:16 AM
RE: RP Rear brake cables - by dickie65 - 06-07-2018, 09:07 PM
RE: RP Rear brake cables - by squeak - 07-07-2018, 01:19 AM
RE: RP Rear brake cables - by Bob Culver - 07-07-2018, 04:44 AM
RE: RP Rear brake cables - by Tony Press - 07-07-2018, 06:04 AM
RE: RP Rear brake cables - by Roger - 07-07-2018, 09:09 AM
RE: RP Rear brake cables - by Roger - 07-07-2018, 10:34 PM
