28-05-2025, 09:32 PM
(This post was last modified: 28-05-2025, 09:49 PM by Nick Lettington.)
I have a special in bits based on an early 30s chassis. It has bowdenex front brakes and a mini hand brake so doesn't use this bit. I can't tell if it's fitted with the one you want or this earlier one...
The only problem is, although it's redundant, it's likely to be a pain to remove. You're welcome to bring a spanner...
That said, if you measure the length of the levers and the diameter of the shaft you might persuade me to have a go.
