28-05-2025, 08:34 AM
There are several points to answer there John...
Firstly, I generally remove the head before lifting out the engine, as well as the major accessories such as starter and dynamo. It's a lot less weight to lift, and fewer things to foul.
Your compression figures do suggest that investigation may be needed. It's the variation that is cause for query.
The head MAY be difficult to remove, or it may not - try it. Mine usually comes off without much bother. You may then be able to see a few more pieces in the puzzle e.g. state of head gasket and (possibly) if you have a burned, sticky or mal-adjusted valve. Ref your comment about 'reluctance to strip an engine without knowing what's wrong' - go for the easy hits first.
Don't smack your manifold studs/ bolts with hammers. These threads are 'delicate' on most blocks I've encountered.
If you have to drill out a stud or bolt, give it your 'A-game'. Wobbling around hopefully with hand drills is likely to end in tears. If at all possible use a jig to guide & centre your drill. Better still get a machine shop to do it perfectly on a pillar drill (though in this instance that would entail stripping back to a bare block). Those among us who are well practiced at this sort of stuff will doubtless reply they can do it by eye - just as some among us can plaster a ceiling without any bother...
Why are you contemplating removing the head studs? I would not attempt this unless I absolutely had to. You will almost certainly break at least half of them. The only real reasons I can think of to remove head studs is if they are damaged or if you need to skim the top face of the block. Removing the nuts should not be problematic, though occasionally you may find a loose stud comes up with the nut.
Best of luck.
Best of luck.
