Head / Block Leak (Possibly)
#25
The 'Indian Rope Trick' is useful in loosening cylinder heads.   With the piston at the bottom of the cylinder, feed a length of thick cord or thin rope into the bore through the spark plug hole (easier if the plug is immediately over the bore).   When you can get no more rope in, give the starting handle a turn.  It will be stiff but you aren't going to do any damage.  This is often just enough to loosen the cylinder head.
Head / Block Leak (Possibly) - by John P - 07-05-2025, 05:54 PM
RE: Head / Block Leak (Possibly) - by Chris KC - 07-05-2025, 06:47 PM
RE: Head / Block Leak (Possibly) - by Alan - 07-05-2025, 06:50 PM
RE: Head / Block Leak (Possibly) - by AustinWood - 08-05-2025, 04:04 PM
RE: Head / Block Leak (Possibly) - by John P - 08-05-2025, 06:49 PM
RE: Head / Block Leak (Possibly) - by Chris KC - 08-05-2025, 07:34 PM
RE: Head / Block Leak (Possibly) - by Steve Jones - 09-05-2025, 11:40 AM
RE: Head / Block Leak (Possibly) - by Charles P - 09-05-2025, 01:35 PM
RE: Head / Block Leak (Possibly) - by John Mason - 09-05-2025, 05:50 PM
RE: Head / Block Leak (Possibly) - by John P - 13-05-2025, 05:34 PM
RE: Head / Block Leak (Possibly) - by Chris KC - 13-05-2025, 05:48 PM
RE: Head / Block Leak (Possibly) - by Hugh Barnes - 14-05-2025, 07:45 AM
RE: Head / Block Leak (Possibly) - by John P - 14-05-2025, 08:33 AM
RE: Head / Block Leak (Possibly) - by AustinWood - 14-05-2025, 08:35 AM
RE: Head / Block Leak (Possibly) - by John P - 27-05-2025, 04:31 PM
RE: Head / Block Leak (Possibly) - by Charles P - 27-05-2025, 05:01 PM
RE: Head / Block Leak (Possibly) - by Malcolm Parker - 28-05-2025, 07:18 AM
RE: Head / Block Leak (Possibly) - by Chris KC - 28-05-2025, 08:34 AM
RE: Head / Block Leak (Possibly) - by Steve Jones - 28-05-2025, 11:51 AM
