26-05-2025, 08:18 PM
(26-05-2025, 07:23 PM)Nick Turley Wrote: Howard it is worth just checking the starter motor commutator, some folks clean out between the segments which makes the motor run slow.
If there is doubt, skim the com so that mic is level with the surface of the copper. It should then do the job as you wish it.
Hi Nick,
I’m ahead of you, commutator was skimmed a few weeks back. The only reason I can think is causing the problem is that the pinion is very loose on the helix. Wear perhaps?
