26-05-2025, 02:35 PM
If you have a starting handle check compressions by turning the engine. If number one is low compared with the others check for full valve travel. After an engine has been unused for a substantial time it might have a stuck valve. I have cured this with the valve cover off and a substantial screwdriver poked into the offending spring and pushing it down with the engine running. Probably necessary to hold screwdriver in place while someone else starts the engine.
