Checking the tightness of halfshafts
I have drilled a second hole in halfshaft to fit split pin,
File V across the end of the shaft in line with existing hole,
Fit nut Tighten up then drill new hole as close to 90 Deg from old hole. File a second V groove for new hole.
V groove will help with alignment of nut to holes in shaft.
RE: Checking the tightness of halfshafts - by dickie65 - 27-05-2018, 06:45 PM
