  • 1 Vote(s) - 4 Average
Correct amount of oil for seven gearbox
#28
(07-05-2025, 08:49 PM)Dave Mann Wrote: Here's a picture of the 4 speed box and filling to the bottom of the filler plug threads is getting close to over flow into the clutch.. It wasn't Austins who recommended filling to the bottom of the filler plug threads.
David states in regard to the 4-speed schromesh gearbox: "½ pint - at this level I needed the top on the box to prevent oil being thrown all over my bench". As a similar example, many machine tool gearboxes with spur gears need only the lowest gear to be half-submerged for the oil to be flung around the whole of the inside. Hence, from the above discussion, is the conclusion that, as a precautionary measure, a 4-speed synchro box might be best with 3/4 pint i.e. enough to lubricate the box yet not so much as to prevent clutch slip?
RE: Correct amount of oil for seven gearbox - by Tony Griffiths - 08-05-2025, 12:45 AM
