23-04-2025, 10:36 PM
I place the head on the block without the head gasket, hold it down with my fingers and turn the engine over with the starting handle.
If you feel it lifting, you will need to remove material from inside the combustion area. If it does not lift it should be fine with the head gasket fitted.
