  • 1 Vote(s) - 2 Average
Dashlamp
(22-04-2025, 08:57 PM)Dave Mann Wrote: The indicator LEDs and LED flasher unit arrived today, now I've heard loads of stories of the flasher unit working OK until the engine was started, I fitted them to the tourer they worked fine then I started the engine and lo the flasher still worked perfectly even when the flasher unit is mounted within 6" of the coil. The flasher unit isn't the cheapest on the market at £11.00 from Classic Dynamo and regulator conversions but they do seem to supply good gear.
It is odd. On one car, the LED flashers don't work with the dynamo charging (solved by wiring them to a small 12-volt battery and using ordinary bulbs), while on another, they work just fine.
Dashlamp - by Dave Mann - 16-04-2025, 08:13 PM
RE: Dashlamp - by Tony Press - 17-04-2025, 03:11 AM
RE: Dashlamp - by Chris KC - 17-04-2025, 07:50 AM
RE: Dashlamp - by Dave Mann - 17-04-2025, 05:18 PM
RE: Dashlamp - by Ivor Hawkins - 17-04-2025, 09:21 PM
RE: Dashlamp - by Dave Mann - 18-04-2025, 09:00 PM
RE: Dashlamp - by Ivor Hawkins - 19-04-2025, 04:12 PM
RE: Dashlamp - by David Stepney - 19-04-2025, 06:01 PM
RE: Dashlamp - by Dave Mann - 19-04-2025, 08:48 PM
RE: Dashlamp - by Tony Griffiths - 20-04-2025, 11:37 AM
RE: Dashlamp - by Mike Costigan - 20-04-2025, 11:51 AM
RE: Dashlamp - by Tony Griffiths - 20-04-2025, 05:00 PM
RE: Dashlamp - by Duncan Grimmond - 20-04-2025, 06:30 PM
RE: Dashlamp - by Dave Mann - 21-04-2025, 09:47 AM
RE: Dashlamp - by Duncan Grimmond - 21-04-2025, 11:26 AM
RE: Dashlamp - by David Stepney - 21-04-2025, 12:12 PM
RE: Dashlamp - by Tony Griffiths - 21-04-2025, 01:12 PM
RE: Dashlamp - by David Stepney - 21-04-2025, 01:44 PM
RE: Dashlamp - by Dave Mann - 22-04-2025, 08:57 PM
RE: Dashlamp - by Tony Griffiths - 23-04-2025, 01:17 AM
