  • 1 Vote(s) - 2 Average
Smiths (magmo) speedometer repair.
Re-building a Smiths Magmo type speedometer, basically swapping parts between my original semi functioning one and a very poor condition one.
So far got all except the milometer working but found the small brass gear that is driven from the worm drive (end of drive cable)
has teeth missing and is BER.
Looking back on old threads it appears these gears are now unobtainium.
'Googling' for similar 20 tooth brass gears does not come up with anything similar. Suspect plastic ones will not be up to the job, but
cannot find similar ones of these either !.
Gear is 20 tooth one, about 9MM diameter, 2MM thick, with a splined hole 4MM diameter. All measurements are approximate.
Anyone ever managed to get replacement gears, not counting removing from a U/S speedometer ?.
Well beyond my capabilites to cut a new gear on a lathe.
Yes I know, run it without the milometer, but it is nice to know how many miles I am doing having done what I thought was
a 30 mile trip which my wife told me was actually 50 miles !.
Martin, GM6VXB
Smiths (magmo) speedometer repair. - by GM6VXB - 21-04-2025, 07:50 PM
