How much compression
There is an old saying that one should "leave well alone". If you are getting 105psi on all four that is good.
I would be more concerned if there was an appreciable difference between them. The more you raise the compression, the more stress you put on the engine and often that leads to unreliability.
Generally the best high torque engines have fairly low compression.
Just my four Penneth.
How much compression - by frequentflyer - 09-04-2025, 10:31 AM
RE: How much compression - by Ray White - 09-04-2025, 10:57 AM
RE: How much compression - by Chris KC - 09-04-2025, 12:46 PM
RE: How much compression - by Malcolm Parker - 09-04-2025, 02:56 PM
RE: How much compression - by Alan - 10-04-2025, 07:27 PM
