09-04-2025, 10:31 AM
Our recently rebuilt mildly hot trials engine has both performed and bedded in well. As a quick health check yesterday I measured compression and we are getting about 105 psi on all 4 bores. We are running a 37 high compression head with the block blended over a bit into the bores. I have a couple of other heads that I want to try on the car but was wondering where to settle in terms of compression ratio/pressure. I need to measure the combustion chamber volume to see if I can skim a bit off to slightly raise the compression but what are most people getting on hotter engines and where to stop? Obviously for trials we are looking for low end torque not high revs power.
