08-04-2025, 06:06 PM
(08-04-2025, 02:20 PM)Austin in the Shed Wrote: The tubular ones often have a pivot point in the middle so you press the gear lever down and it pulls the selector up to clear the step on the reverse selector in the box.
Alternatively grind down the reverse selector to the same height as the others,messy in the car.
Yes, I had a similar version some years ago that had exactly that, a pivot point half way down the tube that enabled one to push down on the gear lever, lifting the selector over the reverse gate. I have it in mind that the origins of the design were Cambridge Engineering, but I am less certain of that point.
