  • 1 Vote(s) - 1 Average
Water leak
#35
I've been away these last couple of weeks, Nick, and so have only, just, caught up with this. Like Malcolm, I know the engine you have and I think we both suggested that it would be a good buy for you when it was advertised. I agree with Malc that this does sound like an isssue with the engine timing or, perhaps, an induction leak. If the engine hasn't been stripped since you got it (and I don't imagine it has) then the valve/cam timing will be as it was so I'm sure that can be discounted. I think you've sealed the carb/manifold joint but what about the manifold/block joint if that's been apart? After that I come back to an issue with the ignition timing/distributor. I'm not sure what distributor your using but did I note DJ4? Not much to go wrong with those but if you want to try fitting one that's proven to work then I have one here you can borrow. I'm not that far from you, on the A19 mid way between Doncaster and Selby.
As to the C/R gears, if you had these done where I think you might have done then, yes, the are noisy at first but do quieten down with running.
Water leak - by Austin Nippy - 18-03-2025, 07:41 PM
RE: Water leak - by Steve Jones - 18-03-2025, 07:59 PM
RE: Water leak - by Austin Nippy - 18-03-2025, 10:30 PM
RE: Water leak - by wild_willy - 19-03-2025, 05:55 AM
RE: Water leak - by Colin Cooke - 19-03-2025, 06:50 AM
RE: Water leak - by Chris KC - 19-03-2025, 08:59 AM
RE: Water leak - by andrew34ruby - 19-03-2025, 11:18 AM
RE: Water leak - by Robert Leigh - 19-03-2025, 12:24 PM
RE: Water leak - by dickie65 - 19-03-2025, 08:43 PM
RE: Water leak - by Austin Nippy - 20-03-2025, 12:38 AM
RE: Water leak - by Austin Nippy - 31-03-2025, 08:39 PM
RE: Water leak - by dickie65 - 01-04-2025, 09:55 PM
RE: Water leak - by Austin Nippy - 03-04-2025, 06:14 PM
RE: Water leak - by Austin Nippy - 03-04-2025, 09:57 PM
RE: Water leak - by stuartu - 04-04-2025, 07:41 AM
RE: Water leak - by John Cornforth - 04-04-2025, 07:43 AM
RE: Water leak - by John Cornforth - 04-04-2025, 09:09 AM
RE: Water leak - by Robert Leigh - 04-04-2025, 09:40 AM
RE: Water leak - by Austin Nippy - 04-04-2025, 10:47 AM
RE: Water leak - by Malcolm Parker - 04-04-2025, 01:58 PM
RE: Water leak - by Austin Nippy - 04-04-2025, 06:31 PM
RE: Water leak - by Austin Nippy - 04-04-2025, 11:42 PM
RE: Water leak - by Tony Griffiths - 05-04-2025, 01:07 AM
RE: Water leak - by Malcolm Parker - 05-04-2025, 10:07 AM
RE: Water leak - by Austin Nippy - 05-04-2025, 10:13 AM
RE: Water leak - by John Cornforth - 05-04-2025, 10:17 AM
RE: Water leak - by Austin Nippy - 06-04-2025, 07:43 AM
RE: Water leak - by Ruairidh Dunford - 06-04-2025, 10:40 AM
RE: Water leak - by Austin Nippy - 06-04-2025, 07:50 PM
RE: Water leak - by Malcolm Parker - 07-04-2025, 08:49 AM
RE: Water leak - by Ruairidh Dunford - 07-04-2025, 09:47 AM
RE: Water leak - by Malcolm Parker - 07-04-2025, 10:20 AM
RE: Water leak - by Ruairidh Dunford - 07-04-2025, 12:02 PM
RE: Water leak - by Austin Nippy - 07-04-2025, 04:20 PM
RE: Water leak - by Steve Jones - 07-04-2025, 04:39 PM
RE: Water leak - by John Cornforth - 07-04-2025, 06:30 PM
RE: Water leak - by Malcolm Parker - 07-04-2025, 06:56 PM
RE: Water leak - by Austin Nippy - 08-04-2025, 07:20 AM
RE: Water leak - by Steve Jones - 08-04-2025, 04:49 PM
RE: Water leak - by Austin Nippy - 08-04-2025, 07:17 PM
RE: Water leak - by Austin Nippy - 12-04-2025, 04:05 PM
