Throttle & Ignition levers - RP
David Mawby writes:
"On the steering column, the top and bottom levers are at 3 o'clock for the throttle and 9 o'clock for the ignition.
The longer bottom lever is the throttle.
Both lever bosses are upwards on both of my RP saloons, it allows space for the bar going from the ignition lever to the distributor, which goes into the hole on the lever from the top."
This agrees with Howard's photo, so I'll go with that. Many thanks for all the replies!
RE: Throttle & Ignition levers - RP - by David Cochrane - 01-04-2025, 10:58 AM
