01-04-2025, 01:03 AM
(This post was last modified: 01-04-2025, 01:05 AM by Tony Griffiths.)
Mine are like the BM143/ BM59 arrangement with the longer for the throttle and the shorter controlling the ignition - but complications can arise if you don't have the original control rods. When I retrieved PL3002, both bronze levers and the control rods were missing (and the horn electrical parts). Having found the levers, the next job was to make up the control rods. The one for the throttle was easy enough, but that for the ignition proved more difficult. Eventually, after a lot of faffing about making up (from memory) at least three examples and experimenting with the clamping of the lever its tube, I managed to get the advance/retard rod to give a complete and correct sweep.
