Having boiled 5/6 times on the way to Curborough and back I've decided to bite the bullet and get my radiator recored.
Have you looked at your block and manifolding? I would certainly do so before shelling out the better part of £1000 on a new radiator (yours looks pretty good to me).
One thing I've found in the past is that if you use a radiator flushing chemical (e.g. as sold by Halfords) it may clean the radiator and cooling passages, but all the debris then collects in and obstructs the side water manifold, and will not be shifted no matter what you do with hosepipes. It needs to be removed and physically scraped out.
Getting your block cooling passages clean means having the engine apart, but the improvement to cooling can be dramatic - depends how bad it was to start with.
Also check your hoses aren't kinked - the bottom hose on A7's is often "pinched". I had one made up with a bend in it for about a tenner.
If after all that you still feel the radiator is underperforming, call Lincolnshire Radiators and have a chat. They will bend over backwards to help you and I imagine they have the means to dip and clean yours (and seal up any leaks which might result), worth a shot prior to a re-core.
