20-03-2025, 12:38 AM
Good evening everyone and many thanks for your helpful replies and advice regarding my water leak (the one on the Nippy at least!).
The engine I bought last year has a 1 1/2 inch crank in the proper ribbed casing. It doesn't obviously have the Chromidium block (no triangle markings etc). It does have a Paul Bonewell cam fitted and a Supalloy head which came with it. The manifold is the correct Nippy one albeit with a downdraft SU carburettor. It was apparently running well in this guise a few months before I found it for sale and managed to snap it up.
My intention was (is) to fit it as bought to see how it goes and then, possibly, try it with the genuine, original Nippy head and Downdraft Zenith carburettor I have on my other engine to see what happens, should the mood take me.
The other engine is currently not running after giving sterling service since 1997 and covering a lot of miles so swapping them back over isn't an option at the moment. I will eventually have it rebuilt (hopefully making it finally free of significant oil leaks which has so far proved beyoned everyone who has tried to make it reasonably oil tight) so that I'll have a good spare in stock for the future.
I think I'm going down the Helicoil route first as this sounds like the most obvious solution (complete with sealer and PTFE tape) as this won't necessitate changing any of the studs which all look pretty new and I also have a 5/16BSF helicoil kit in stock. I trust that this all does the job...
The biggest challenge will be finding sufficient time, prior to the excellent Sevens to the Sea event, to try to repair this due to pressures of work and other non-A7 related commitments at weekends. I'll let you know how I get on with it once I've had a go.
Best wishes,
Nick
Best wishes,
Nick
