DK4A Timing Query
Hi John P
I am assuming this is a low power problem and is not accompanied by any signs of misfire.
This doesn't have the characteristics i would associate with a timing error, unless it's really extreme. I suggest you buy or borrow a xenon timing light (about £25 new). If your car is 6 volts you will also need a small 12 volt battery for the light. Fix a pointer near the camshaft pulley and make a TDC mark on the pulley rim. You will then be able to see what the advance characteristic is, and how good or bad the timing scatter is. The internal mechanism of the DK4A is rather sensitive to small amounts of wear in the various pivot points. As you know, the 8 degrees by Lucas convention are distributor degrees, so the advance range is 16 crank degrees. With 6 degrees static advance that will give you 22 degrees maximum advance which should be more than enough.
In my experience, the handbook settings for advance are a bit too much for modern fuel and engines modified for better breathing. Too much advance gives harshness around 1800 to 2500 RPM. You won't get pinking with modern high octanes.
If your problem is fuel related, it's possible that you are running a little lean at low RPM/low airflow. A lean mix may not be so lean as to obviously misfire, but will still be down on power. As a diagnostic, try pulling out the "choke" a little and see if it improves matters.
My own car uses a 1 1/8 inch SU with a GG needle. The mixture has been checked on the road with an oxygen sensor in the downpipe and is close to ideal. As you have a larger SU it's likely that even at high RPM/high airflow the piston is not fully lifting. This isn't a problem in itself but can make the choice of needle more critical because a lot of the time you are operating near the "thick end".
The original 3 speed box was suited to an engine with fairly restricted breathing and maximum torque probably around 1800 RPM. With better breathing the torque peak moves up to nearer 2500 RPM so it's also possible that the widely spaced ratios are no longer ideal. You end up with a bit of a gap where 3rd is too high and 2nd is too low.
DK4A Timing Query - by John P - 16-03-2025, 07:02 PM
RE: DK4A Timing Query - by Howard Wright - 17-03-2025, 08:19 AM
RE: DK4A Timing Query - by John Cornforth - 17-03-2025, 09:10 AM
RE: DK4A Timing Query - by Chris KC - 17-03-2025, 11:13 AM
