16-03-2025, 07:02 PM
I've got an Ulsteroid fitted with a lightly tuned 2 bearing engine, an HS2 SU carburetor and 3-speed box. It has a later "D" type axle which I think came from a van so presumable is a lower ratio.
There is some wear in the distributor but I don't think it's that bad.
The car starts easily and runs OK, if a little rough, but seems to lack power at lower speeds. I've just been out fot another test drive and as soon as I start to climb even a slight hill in 3rd at 30 mph the speed quickly starts to drop and I need to use 2nd to carry on. In 2nd it climbs quite well and, if anything, the engine is somewhat smoother.
Presumably when I change down and the revs increase the auto-advance increases the advance so does this suggest the static advance need to be further increased. At the moment static timing is set to around 6 degrees BTDC (possibly a little less) and the distributor has an 8 degree action plate.
I've only ever driven this car so don't have much to compare it with.
John.
John.
