No start.
I've never used a voltmeter to get an A7 started.
Just work systematically through the ignition components, one by one, and check they are in place and correctly connected and any contacts are clean.
If that gets you nowhere, replace components one by one with other (hopefully new or sound) parts. If you still have your old coil which was working, put it back again.
Think about what you have changed since the car last ran, and look at that first.
My top picks are
(1) dirty or mal-adjusted points
(2) broken LT lead
(3) poor connections, anywhere
(4) carbon brush in distributor cap fallen out
(5) sheared distributor drive pin
I never take the car anywhere without a selection of ignition parts, usually in multiples, stashed in the boot. If I have space I carry a fully assembled distributor or at least the base plate ready to swap.
Best of luck...
No start. - by Ray White - 15-03-2025, 03:12 PM
RE: No start. - by andrew34ruby - 15-03-2025, 04:07 PM
RE: No start. - by John Cornforth - 15-03-2025, 05:07 PM
RE: No start. - by Ray White - 15-03-2025, 05:51 PM
RE: No start. - by Charles P - 15-03-2025, 06:17 PM
RE: No start. - by John Cornforth - 15-03-2025, 07:01 PM
RE: No start. - by Ray White - 15-03-2025, 07:09 PM
RE: No start. - by Nick Salmon - 15-03-2025, 08:04 PM
RE: No start. - by Ray White - 15-03-2025, 09:10 PM
RE: No start. - by John Cornforth - 16-03-2025, 09:06 AM
RE: No start. - by Ray White - 16-03-2025, 09:57 AM
RE: No start. - by Chris KC - 16-03-2025, 10:52 AM
RE: No start. - by Ray White - 16-03-2025, 11:34 AM
RE: No start. - by Duncan Grimmond - 16-03-2025, 01:37 PM
RE: No start. - by Ray White - 16-03-2025, 02:05 PM
RE: No start. - by Duncan Grimmond - 16-03-2025, 02:18 PM
RE: No start. - by Ray White - 16-03-2025, 02:36 PM
RE: No start. - by andrew34ruby - 16-03-2025, 04:08 PM
RE: No start. - by Malcolm Parker - 16-03-2025, 05:38 PM
RE: No start. - by Ray White - 16-03-2025, 05:46 PM
RE: No start. - by Ray White - 16-03-2025, 07:00 PM
RE: No start. - by John Cornforth - 16-03-2025, 08:40 PM
RE: No start. - by Ray White - 16-03-2025, 08:57 PM
RE: No start. - by Ray White - 17-03-2025, 12:40 PM
RE: No start. - by Ray White - 17-03-2025, 02:16 PM
RE: No start. - by John Cornforth - 17-03-2025, 02:39 PM
RE: No start. - by Ray White - 17-03-2025, 03:18 PM
RE: No start. - by andrew34ruby - 17-03-2025, 06:34 PM
RE: No start. - by Ray White - 17-03-2025, 08:16 PM
