No start.
Hi
I'm not sure what you mean when you say you are taking a current reading "across the points".
Voltage is measured across a component by connecting a voltmeter in parallel
Current is measured through a component by connecting an ammeter in series
The current through the coil with the points closed should be about 4 Amps, i.e. 6 Volts divided by 1.5 Ohms. With the engine running this current pulses on and off in about a 50:50 ratio, so the average current is about 2 Amps.
If your coil current really is 0.12 Amps you have a problem, but if you have connected your ammeter in parallel with the closed points it will only be measuring part of the coil current.
No start. - by Ray White - 15-03-2025, 03:12 PM
RE: No start. - by andrew34ruby - 15-03-2025, 04:07 PM
RE: No start. - by John Cornforth - 15-03-2025, 05:07 PM
RE: No start. - by Ray White - 15-03-2025, 05:51 PM
RE: No start. - by Charles P - 15-03-2025, 06:17 PM
RE: No start. - by John Cornforth - 15-03-2025, 07:01 PM
RE: No start. - by Ray White - 15-03-2025, 07:09 PM
RE: No start. - by Nick Salmon - 15-03-2025, 08:04 PM
RE: No start. - by Ray White - 15-03-2025, 09:10 PM
RE: No start. - by John Cornforth - 16-03-2025, 09:06 AM
RE: No start. - by Ray White - 16-03-2025, 09:57 AM
RE: No start. - by Chris KC - 16-03-2025, 10:52 AM
RE: No start. - by Ray White - 16-03-2025, 11:34 AM
RE: No start. - by Duncan Grimmond - 16-03-2025, 01:37 PM
RE: No start. - by Ray White - 16-03-2025, 02:05 PM
RE: No start. - by Duncan Grimmond - 16-03-2025, 02:18 PM
RE: No start. - by Ray White - 16-03-2025, 02:36 PM
RE: No start. - by andrew34ruby - 16-03-2025, 04:08 PM
RE: No start. - by Malcolm Parker - 16-03-2025, 05:38 PM
RE: No start. - by Ray White - 16-03-2025, 05:46 PM
RE: No start. - by Ray White - 16-03-2025, 07:00 PM
RE: No start. - by John Cornforth - 16-03-2025, 08:40 PM
RE: No start. - by Ray White - 16-03-2025, 08:57 PM
RE: No start. - by Ray White - 17-03-2025, 12:40 PM
RE: No start. - by Ray White - 17-03-2025, 02:16 PM
RE: No start. - by John Cornforth - 17-03-2025, 02:39 PM
RE: No start. - by Ray White - 17-03-2025, 03:18 PM
RE: No start. - by andrew34ruby - 17-03-2025, 06:34 PM
RE: No start. - by Ray White - 17-03-2025, 08:16 PM
