09-03-2025, 10:37 PM
On the 1924/25 chassis the nosepiece (BR11) had a separate plate (BR22) for mounting the starting handle bracket and that nosepiece is fragile (2 of them have broken on my Chummy). The first break (in the late 1950s) was solved by fitting a later nosepiece (BR47) which has provision for mounting the starting handle bracket and is much stronger. In c.1980 I replaced the later nosepiece with an original one, and this broke a few years later. It was repaired by welding and then the BR22 plate was welded to the nosepiece. This repair has lasted for over 35 years.
