04-03-2025, 01:27 PM
Goldnrust - thanks for your insight. Do I take it you pressed it with a vice, or do you have something else to apply enough pressure? I got one hub together yesterday except for the last mm as I mentioned above. I have pressed the bearing in either side again and will have another go later. Trouble is, I ruined the gasket getting it apart again so I have ordered a couple more. Hamfisted amateur that is the problem. It isn't really rocket-science, but it times it might as well be!!! - Thanks again.
Alan - roll pins. I haven't used those since I was replacing Austin Maxi CV joints 50 years ago. What a great idea - thanks - hope to see you Thursday.
Dave
Dave
