Valve guide replacement
I put my guides in the freezer and the block in the oven (for fitting to a naked block). They were still a decent interference fit needing a drift to get in and a ream back to correct size.
But, for removal, the expansion coefficient of brass is higher than cast iron, so I guess that if heated as a complete assembly the guides will actually tighten in the block. The reverse would thern be true so cooling will make them 'looser' and so aid removal
Valve guide replacement - by Peter Naulls - 10-02-2025, 10:30 PM
RE: Valve guide replacement - by Chris KC - 11-02-2025, 10:16 AM
RE: Valve guide replacement - by Andy Bennett - 11-02-2025, 10:17 AM
RE: Valve guide replacement - by Peter Naulls - 11-02-2025, 10:59 AM
RE: Valve guide replacement - by Howard Wright - 11-02-2025, 11:31 AM
RE: Valve guide replacement - by Peter Naulls - 11-02-2025, 06:55 PM
RE: Valve guide replacement - by Peter Naulls - 12-02-2025, 08:31 PM
