Car type: Ruby + others
This is quite a time appropriate thread.
I have accidentally just acquired a flathead Ford V8 engine from 1936 - its UK built, so is the smaller 2.2 litre displacement (and its actually quite a compact thing).
In an idle moment I was thinking whether it would, or could be made, to fit an Austin 7 chassis. Does anyone know of this being done before?
So, what about gearboxes, and brakes? Were the different engines mated to the original (rather short) seven gearboxes? Or, for example, was the A-series engine using an A-series (rather long) gearbox? And if so did that mean doing away with the brake cross-shaft?
I have seen a few of the ford sidevalve engines described that look to have been coupled to a standard A7 gearbox via a second short propshaft infront... not sure where the box was mounted.
Car type: Single seat special
Interestingly, Paul is now converting this lovely machine back to Austin 750 power, in order to compete in the Bert Hadley Memorial Championship.
No Relation to Paul!
Cheers,
Colin.
1932 single seat special "The Moose"
I've just had a message from Paul, who is on holiday in Sri Lanka just now, and can't remember his password to post a reply. He tells me he will be able to give lots of information once he gets back after the 18th. He says "I have the engine mounts and cross member required. Also a nicely prepared 998 which Mr. Wood may be interested in."
Cheers,
Colin.
