18-10-2023, 10:29 AM
Hello, my first post on here.
After losing oil pressure, had the engine out and discovered damage in the oil pump. A piece has broken off in between the holes within the chamber.
I've over bored another oil pump but looking at the two pairs of holes in the chamber one pair has only a very thin piece of material separating them.
This piece is missing on the old damaged one.
I'm just wondering whether its best to take this piece out rather than it break off and cause more damage?
A third oil pump has the same feature and is partly split already.
I guess the extra material will support the vanes better and reduce wear but it seems to me it would be better to remove it.
