11-02-2023, 02:00 PM
As I was working on the axels on the ruby I noticed that when i’d removed the radiator Ymir had left a stud behind. does anyone know Place in Hampshire that can repair the studs?
Radiator repair
12-02-2023, 12:05 AM
I repaired both studs on the Ruby
Used small metal plate with stud attached then araldite to radiator
12-02-2023, 11:28 AM
Thanks. I was thinking about that technique.
I have several spare radiators in my stock pile but only the one has side panels. The rest are exposed cooling fins. Is that because they are from early ruby’s? Steve |
