Car type: 1929 austin 7 chummy AD
I have been driving my seven and the rattle from the clutch thrust race has been getting worse. It stops when i push it in. I already tried to oil it but to no avail. I was told that I need to replace it. Can I do this with the engine still in the car or do i have to fully disassemble. I do not have an engine hoist so this would be mostly by hand. Please tell me what to do.
Yes, you will need to remove the engine. I usually remove the engine and gearbox from the car together and separate them once they are out, as it makes aligning the master spline on the clutch driven plate easier. Replacement of the clutch thrust bearing is fairly straightforward. The engine and gearbox unit is not too heavy and is manageable between two people without the need for an engine hoist. Leon and I have managed it between us and we are both only about 8 stone each.
Car type: 1933 RP Standard(ish) Saloon
Not exhaustive and may need to be modified for earlier models (this refers to a 33 Saloon)
Austin Seven RP Engine/Gearbox removal
• Disconnect battery
• Protect front wings/headlamps with old towels/curtains
• Remove bonnet
• Remove bonnet stay complete with horn
• Remove front number plate
• Remove starting handle
• Drain radiator
• Loosen top and bottom hoses at head & water branch
• Remove Radiator shell and radiator complete with top/bottom hoses
• Remove gear lever. Stuff gearbox top cover with paper towel.
• Remove floor mat & propshaft tunnel cover
• Remove bolts securing propshaft to output flange
• Remove clutch lever top (or complete lever from release shaft if you haven’t got a modified floor pan )
• Remove flywheel cover plate
• Disconnect speedo cable from gearbox
• Disconnect fuel pipe from fuel pump.
• Disconnect choke cable and throttle linkage
• Disconnect oil pipe to dashboard gauge from back of crankcase
• Disconnect starter cable from starter motor
• Disconnect starter pull cable from solenoid
• Disconnect secondary earth cable from cylinder head (if you’ve got one)
• Disconnect earth strap from timing case
• Disconnect dynamo cables from dynamo
• Remove adv/retard lever from distributor
• Remove HT lead from coil.
• Disconnect LT lead from distributor
• Remove four bolts holding exhaust downpipe to manifold
• Remove n°3 spark plug & replace with lifting hook
• Remove engine mounting bolts
• Lift unit clear with hoist tilting unit backwards to clear nose piece and throttle linkage
• Push car backwards out of the way and place unit on stand/workmate
• Set handbrake on car once it’s out of the way.
• Replace flywheel cover to prevent something falling in.
• Have a cup of tea for a job well done.
Good list there Bruce, but you forgot all the swearing when you have a Nippy sump like mine has!
In fact I have the same job to do on mine as the bearing is noisy and thinking I may have to remove the sump to get the b*gger out!
So after i get the engine out and the tranny apart what do I do. Sorry for being clueless. I'm very good with a wrench but I dont want to break anything I will regret. What else on the car should i fix or work on while the engine is out. I figured replacing the trans seals and gaskets but what else?
