Some years ago when starting my 1932 A7 RN style van I had two back axle/torque tube assemblies. One was from the van and the other from a later (year unknown) scrapped Ruby. I find the the CW & P ratios are both 8/42 ie. 6.25
Looking in the source book page it says the CW & P ratio is 8/45. I thought I would get up hills better with the 8/45 but don't have much choice without spending a lot of money. Out of interest can anyone shed any light on this anomaly?
In any case would the change in ratio really make any noticeable difference?
Nick,
May be a typo but 8/42 is 5.25 not 6.25.
Alan
20-02-2022, 05:08 PM
(This post was last modified: 20-02-2022, 05:08 PM by Parazine.)
Most A7's were 8/42 or 5.25:1 from 1932 onwards. Late in the production run, the ratio was unified with the Big 7 at 5.125:1 (8/41).
Vans and the early Sports 65/Nippy were 5.625:1 or 8/45. The last Nippy and Speedy models were 5.25:1 I believe.
Over the years, these ratios may have changed about as axles were swopped between cars and CWP sets were changed/upgraded. A friend bought a Ruby in 1978 with a 5.625 CWP and it was awful! 45mph flat out but went up hills well. The change in ratio made a dramatic difference.
So your van axle may have started life on a car or had its internals replaced in 1952 or another myriad of reasons as to why it's apparently incorrect now.
Car type:
the value of not over-gearing (mentioned a lot on here) was brought home when talking to a taxi driver Prius owner who had plainly been experimenting to find a sustainable solution for a huge annual mileage. He found that on raising the profile of standard wheels from 45 section to 50 then 55 (increasing diameter in order to give better ride height on rural roads) the average mpg decreased from 65 to 58 to 52. Remarkable. Presumably mostly torque-related and also rising drag as it gets less near the road.
So Parazine do you think I would have a big difference if I changed to 8/45 CW & P? The pepped up engine should be ok revving a bit higher.
That odd my EB65 will do 45 mph in third gear and 65mph + in fourth ( best recorded against GPS is 72 MPH )
From old road tests and many on here the original 4.9:1 is/was considered overgeared and despite faster running today several have converted early cars to the common 5.25:1. To the occupants 5.25 Sevens seem high revving but are no more and less so than many older cars (1950s Minx, A40 A30 ect) and much less than commercials (Fordson A40 pick up etc). Revs do not prolong the crank. It is a bit surprising that the higher speed sports models were lower geared, but the wind drowns out the din.
Economy not a consideration for most owners but generally improves as the gear revs are lowered. Unless on more sophisticated carbs the engine is more often prodded into enrichment territory, possibky the action of the Prius computer. I assume he corrected for the greater distance run. Peak power on pre 1936 is about 3200 rpm, admittedly a speed hard to maintain in top on any hill. Lowering the gearing further reduces the reasonable speed in 3rd, already modest at prudent revs.
Well Nick, that engine should fly!
Whereabouts in the country are you?
