I recall there was a discussion recently about a bar that fits across the back of the radiator and strengthens the cowl. A search doesn't seem to turn up what I recall. I'll note that Chris Gould's Ulster book says that the clearance between the radiator and fan should be 1/8th inch which doesn't seem to allow enough room.
Erich in Seattle
31-01-2018, 05:00 AM
(This post was last modified: 31-01-2018, 05:02 AM by Ian Williams.)
The bar is arched to clear the fan, I don't have a picture to hand but can take one
Thank you, Ian. I would like to see it, along with rough dimensions.
Best,
Erich
The brace depicted in Ruairidh's picture is made from 1 5/8" x 1/8" mild steel flat bar, and the bow is 2'' high, easy enough to make.
Car type:
....and if you can't, Rod Yates has them ready to bend to suit your aperture...
Just wondering if Gordon England cars with
headlamps bolted directly to the cowl
Used a strengthening bar?
My car has CAV lamps( NOS!) but I still
Have to fit them.
Regards
Bill G
Aka AllAlloyCup
Thank you all.
Best,
Erich
