Ruby MK1 pinion shaft thread
Would anyone have the correct thread size for the pinion shaft of the torque tube?
I now have the pinion flange off but the shaft thread is damaged. So I will need a replacement nut as well as a correct die to recut the shaft thread.
Thanks!
refer Pinion Nut post above.
