04-03-2021, 03:48 PM
Having taken both rear dampers to bits and cleaned up the brass discs and sanded the wooden discs , to grease or not to grease them on reassemble?
Rear dampers
04-03-2021, 03:54 PM
It's a friction damper. Why would you want to grease it?
04-03-2021, 03:56 PM
I have always put a thin smear of grease on the wooden discs on reassembly, others do not! If the discs are made out of brake lining type material, they presumably should not be greased.
04-03-2021, 04:15 PM
Because I have seen it recommended somewhere in the dim and distant, I always reassemble the dampers with beechwood disks with a thin coating of lithium grease. Works just fine. As had been said already, no grease if the disks are a ferodo type material.
04-03-2021, 08:06 PM
i always here people say they were oiled originally, when they were wood.
id imagine as the oil sinks in, its more about treating the wood. stopping it shrinking/cracking etc. rather than adding to friction. modern discs are a friction disc material, much like a clutch linning, i wouldnt grease them. tony.
05-03-2021, 01:22 PM
The rear dampers are exposed to the elements and if they were dry and ungreased/oiled, they would swell when wet, affecting the damping (probably to the better). Applying a thin layer of grease or oil will lessen the tendency to swell in wet weather.
08-03-2021, 04:50 PM
I discovered that all the dampers on my 1932 Tourer were very tired, especially the rears that were still running wooden friction discs, had totally lost their lignum vitae central bushes and with tired coil springs were providing virtually no damping at all.
I happen to know Dan White, a long time suspension engineer and keen Austin 7 owner who, with another suspension expert, runs Suspension Supplies Ltd (SSL). He offered an interesting explanation as to why friction dampers worked better in the early years of motoring. Roads surfaces then were graded for horse drawn vehicles, with typically 20mm granite gravel giving a well shod horse good grip. This surface meant that a vehicle's suspension was constantly receiving low amplitude, high energy inputs (vibrations), keeping it 'on the go' and, as a result, friction dampers were less prone to suffering from stiction. With today's smooth (if only!) tarmac roads, the suspension is receiving fewer inputs and therefore stiction has become a much more obvious problem, whether one is running wood, Tufnell or a Ferodo type friction material. Lubrication of the discs helps to overcome stiction but, invariably, there is then inadequate damping. Looking to solve the problem, SSL have identified a modern friction material with virtually no stiction, enabling one to set a damping force that controls suspension movement but one that is also smooth and progressive. They currently make friction discs in this material for Bugattis, Bentleys, Rileys and also Austin 7s. I decided to fit a set to my Tourer and although, thanks to Covid, I have not covered many miles since doing so, the result is most encouraging. What was most noticeable when assembling the dampers and adjusting the damping force was the absence of stiction which made it very easy to set and repeat the desired figure simply using a spring balance. I should add that stiffer coil springs were necessary at the rear to achieve the required damping force; double coil springs might possibly be another approach. I hasten to add that I have no financial interest in SSL but thought that their insights might be of relevance to this discussion.
08-03-2021, 09:37 PM
This is very interesting John. I have noticed that it is possible to get very good performance from the later friction material in the wet but in the dry, stiction becomes a real problem.
I would be very interested to know your impressions once you have used the SSL discs more extensively. I was about to start my own experiments trying different lubricants but perhaps I'll wait a while!
10-03-2021, 12:52 PM
Peter,
I'll certainly report back in due course but it won't be for a while as the gearbox has to come out (jumping out of second). In the interim, you could always chat to SSL because Dan White has been using the no-stiction discs on his RP saloon for some time now. I can't remember how much the discs cost but it wasn't a lot and it might be worth giving them a try. |
