12-12-2020, 04:50 PM
I'm making up new ht leads, solder the little hole on the spade end or not ?
Spade ends ht
12-12-2020, 05:44 PM
Yes because they don't work very well if you crimp them.
Cheers, Dave.
12-12-2020, 06:07 PM
I do
(and those are words I think twice before uttering).
12-12-2020, 06:22 PM
"I am" is apparently the shortest complete sentence in the English language
"I do" is definitely the longest sentence... Aye Greig
12-12-2020, 06:57 PM
I have done
(Just to be different.) I also use heat shrink cable wrap as it supports the cable and helps prevent vibration fatigue on the copper core. Cheers Howard
12-12-2020, 07:21 PM
I never have done and never had any issues.
I use a spade bit to open up the hole and push the cable right up to the plug hole. Then crimp in a smooth jaw vice.
13-12-2020, 01:07 AM
Always
13-12-2020, 06:27 AM
This was laboured recently. Solder tends to wick up the wires making these rigid and prone to fail esp with manual advance. (Solder should not be used for wires retained by grubscrews as the solder creeps and the screw loosens)
Spade lugs look nicely original (I soldered but used the very minimum)
13-12-2020, 09:30 AM
The hole filling with solder lets you see the solder has wetted inside nicely.
